When raising the RF head sail, it is extremely difficult to raise the sail. I need to use great force on a winch to get it up. It comes down easily, so it is not a pinched foil. My guess is a seized sheave at the top of the mast. Is this something that I could do from a bosun's chair or would I need to call a rigger? Any tips for me if I were to do it? Special parts?
C36 1989 Standard Rig
No advice on changing the halyard sheave. But have you tried something like SailKote? I had a very, very difficult time getting my genny up this spring until my marina operator sprayed SailKote in the slot. Up it went easy as pie, I was seriously embarrassed. It would come down pretty easy but, I guess with the weight of the sail plus the friction in the slot, it did NOT want to go up.
[QUOTE=plaineolde;6743]No advice on changing the halyard sheave. But have you tried something like SailKote? I had a very, very difficult time getting my genny up this spring until my marina operator sprayed SailKote in the slot. Up it went easy as pie, I was seriously embarrassed. It would come down pretty easy but, I guess with the weight of the sail plus the friction in the slot, it did NOT want to go up.[/QUOTE]
I wish that were the solution, but I had a helper with the spray can spraying as he fed the sail onto the foil. On one occassion, one fed/sprayed, one hauled on the halyard at the base of the mast and the 3rd guy was on the winch.
Thanks for the reply
Domani: Changing out the sheave on top of the mast is not a job with the mast up, Well on a 1990 36 anyway. I have a picture that is a few months old that I can send you if you email me that I took of our mast when it was on our boat while we were in transit on the Erie Canal. It will show you what you see. The top of mast has a cap that has to come off to get the sheaves out as it set in a recess and on a pin. The stock sheave is nylon with a bronze bushing.
Take a look in your owners manual, it should have a good diagram of your mast head. It can be done with the mast in the boat, but I suggest using a cherry picker as I think both the fore and back stays need to be removed to get the mast cap off.
Ken and Vicki Juul
SV Luna Loca
C34 #1090
[QUOTE=mutualfun;6745]Domani: Changing out the sheave on top of the mast is not a job with the mast up, Well on a 1990 36 anyway. I have a picture that is a few months old that I can send you if you email me that I took of our mast when it was on our boat while we were in transit on the Erie Canal. It will show you what you see. The top of mast has a cap that has to come off to get the sheaves out as it set in a recess and on a pin. The stock sheave is nylon with a bronze bushing.[/QUOTE]
Randy,
Thanks for the offer of a photo...I'll take it.
[email]kapmerika@verizon.net[/email]
Bill:
Your pictures are on the way. Larry also got them and he will post them on the site for others also.
Randy
Domani,
The mast head sheave is not the problem.
Dirt and gunk in the sail track is!
Try raising the sail with out the sail slugs in the slot, I bet it will go up, no sweat!
You need to clean and lube the sail slug slot.
If you can raise the sail without the slugs in the slot, let me know. I have a simple solution for you to try before you go renting a "cherry picker".
By the way here are a couple pictures of my mast head, It's easy for me to have pictures, I pull the mast every season.
Bill Matley
Cheboygan, Michigan
Lakes Huron, Michigan,
Canadian North Channel
"Spirit of Aloha" Hull #1252
Bill,
The next time that I drop the head sail, I will try hoisting it without putting the luff tape into the slot in the RF foil to test your theory, but in the meantime, go ahead and send me your easy fix that you had mentioned in your posted msg.
Much thanks,
Domani,
I don't want to use our forum for any commercial purpose.
I need your e-mail address and I'll write to you directly.
But, just so you know what I am talking about, I had a problem with a dirty/sticky mast sail slot, it was so bad I couldn't raise the mainsail even with the help of the anchor winch! It thought I had a damaged slot but I could see the slot with my binoculars and it looked fine.
So, in desperation, I built a slot cleaner made from an old nylon web belt. I cut the belt width to fit into the slot and made the belt about 1 foot long. Then with some 1/8 inch nylon line I tied one end to my mainsail halyard and put a messenger line on the bottom end.
You SATURATE this web belt with a cleaner or if you think you just need to lubricate your slot, use some Sailkote. When it's soaked, feed the web belt into the slot and run it up and down your mast several times.
That did the trick, big time! Now I clean and lube my mast slot once each season and that solved the problem.
I have shared this slot cleaner with other boaters I have met who from time to time mention they are having a hard time hoisting the main sail.
I have been making these slot cleaning belts myself and selling them to boaters who need them. Not a large expense but it costs me for materials and shipping.
So, try lifting your main without the slides inserted in the slot, if you have no problem lifting the weight of your main sail, it's probably dirt etc. gumming up your slot. Not a problem with the sheave at the top of your mast.
If you want me to make a slot cleaner for you, send me an e-mail message and we can do our business off this forum.
use [email]sales@mat-tech.net[/email]
Bill Matley
Cheboygan, Michigan
