Mast Halyards clanking
richie30's picture
richie30
This was a problem on our 34, and did not bother us on our 36, until 2 weeks ago. in a slightly swaying anchorage or marina, our internal halyards now clank inside the mast. did i just not notice this before....or does hearing improve with age? I am not sure what might have been keeping them quiet in the past, or if a clip or something that holds them is loose.
Any thoughts would be appreciate.
Rich
"Pazzo"
Hull # 1670
C36 MK 2 / 1998
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
Rich,
This has been a much discussed topic. Here is how to access past discussions; Click Search and select "Show Threads". Type in "mast". Click Go. There you will find three pages of threads with the word "mast" in them. A quick glance will show two likely threads on this topic, but the most thorough one is on the third page of search results. For your convenience, here in the link to the article directly,
[URL="http://www.c36ia.com/forums/showthread.php?t=28&highlight=mast"]http://www.c36ia.com/forums/showthread.php?t=28&highlight=mast[/URL]
I hope this helps.
therobesons's picture
therobesons
[QUOTE=richie30;2292]This was a problem on our 34, and did not bother us on our 36, until 2 weeks ago. in a slightly swaying anchorage or marina, our internal halyards now clank inside the mast. did i just not notice this before....or does hearing improve with age? I am not sure what might have been keeping them quiet in the past, or if a clip or something that holds them is loose.
Rich
"Pazzo"
Hull # 1670
C36 MK 2 / 1998[/QUOTE]
If it the halyards or other wiring?
Halyards seem to have a softer thud and wires have a sharper clank.
If it is halyards, just tighten then.
If it is wires , good luck and have then rerun next time you take the mast down.
Bob
1985 Std Rig C-36, Hull #374
San Pedro, Cal
john hough
Richie I put a second tube it the mast to hold the extra wires that weren't there before. Took care of 90% of noise. Could run halyards in if needed. Only issue I've had is finding broken rivets in mast after a few years. I did this my self when mast was down.
