Foredeck padeye
9 posts / 0 new
Anonymous (not verified)
Foredeck padeye
I am setting up a homemade sprit pole for C36, a 1999, and I want to install a padeye on the foredeck. Should I through bolt it? - but the deck in that area is fairly thick. Or simply screw it into the deck?
Tom Bolen
C36 - SPIRIT #1780
dwarburton
Tom,
You will definitely want to through bolt it, with a good sized backing plate.
Are you familiar with the process for through bolting hardware?
Dave
Dave
Ballena 1995 Mk II #1445
tangled
Thanks for getting back. I bought a backing plate to match the padeye, and both have holes for a 1/4" screws.
Should I just mark and then drill through and measure to confirm the length of the screws needed. I would also use epoxy and get cap nuts. Right?
Thanks very much
Tomn B
Allan R's picture
Allan R
Below is a link you may want to view before proceeding, it does a much better job in explaining than I could. You don't want to "just" drill a hole the same size as your bolt.
[URL]http://www.pbase.com/mainecruising/sealing_the_deck[/URL]
Allan Rex
# 2216
dwarburton
Allan,
Thanks for that very informative article. Is there a place on the website to put a permanent link to articles like that?
The only thing I would add is that if you do not have a Dremel, a nail with the head cut off, and a 90 deg bend at the tip is a serviceable alternative.
It will bounce around inside the hole a bit, but it will remove the balsa.
Dave
Dave
tangled
Thanks very much fellas. Allan that site is an excellent gobye.
Thanks again.
Tom Bolen "SPIRIT" #1780
Allan R's picture
Allan R
The credit and thanks goes to "Maine Sail" for that one. Hopefully you also had a chance to view some of his other fine "How To's"
[URL]http://www.pbase.com/mainecruising/boat_projects[/URL]
Allan Rex
# 2216
Dave,
A link to Maine Sail's website has been on our website for over a year!!!
[url]http://www.c36ia.com/node/948[/url]
dwarburton
When I go to the web site, I never get past the forums. I guess I need to widen my horizons!
Dave
Dave
