I'm having an issue with my in mast furler sticking and not wanting to roll out. Any suggestions?
Nancy
Cat's Meow #2046
San Francisco
Nancy
Cat's Meow #2046
San Francisco
2002 MK II
Nancy
Cat's Meow #2046
San Francisco
Nancy
Cat's Meow #2046
San Francisco
2002 MK II
Theme by Zymphonies
I had a similar problem when the halyard was too tight. If the sail is wrinkled when being furled, it can be difficult to unfurl...I had to grab the clew and work it out of the furler by hand.
2000 MKII
#1896 Sweet Caroline
I had to help a buddy on his Beneteau last year. He had to go up the mast in a bosun chair with a plastic kitchen spatula to poke and prod the wrinkles past the slot while I pulled the outhaul.
1. Add some tension to the outhaul when rolling up the mainsail into the mast
2. Release some tension on the Halyard
3. Check where the mainsail foot is attached to the furler, this can sometimes get stuck if the sail tension is too loose.
4. If in salt water be sure to hose off the roller furley assembley
Hilbre 2135 - Lake Mead soon to be in Long Beach with fleet #2
John Meyer
Hilbre
C36 MKll, Hull 2135
