Mast Gyrations
carlsonl
Mast Gyrations
I'm new to this community, but am enjoying and learning from these discussions. Here's the problem. At the slip in a 12-15 mph SW wind our mast is flopping around like a fish dying on the dock! Our heading at the slip is due south. My wife is not happy! I have played around with tension on the boom, main halyard, jib sheet, forestay, backstay tension, etc. I'm in big trouble with my lady. It shakes the V-berth like a tsunami! I know there is a solution! Help Me! It's a marital crisis! Refuge - 01 MKII Tall Rig, I forgot the hull numer.
Thanks! REFUGE
I usually get up and say: "Oh, honey, the wind's 12-13." "How do you know," she says...
Don't sweat it, it happens.
See this: [url]http://www.c34.org/faq-pages/faq-mast-pumping.html[/url]
dwarburton
I have a tall rig and it does the same thing. I think that the vibration comes from the furler. Sometimes if I tighten the jib sheets it seems to help.
It's a little crazy. The 36 has a mast like a telephone pole. Nothing should make it vibrate.
If I had a tension guage and a little patience, I might try tightening up on the forward lowers, this will pull the center of the mast forward a little, and the top of the mast back, tensioning the forestay.
Just a thought.
Dave
Dave
Ballena 1995 Mk II #1445
Dave, did you read the link I referenced? Tension has nothing to do with it, unless the forestay is so loose any wind will make it whip around..
OK, whiles on the subject, what is the proper procedure to tension the forestay.
dwarburton
Stu,
I guess I should have read the link you provided. Thanks for pointing it out. I am familiar with vortex shedding, (Having seen the Tacoma Narrows bridge film a few times. ) It just never occurred to me that it could be happening to the mast. It may have something to do with the C36 and C34 having a single spreader rig.
I will try the trick with the halyards. Or perhaps I will market an overpriced marine-grade widget to cure the problem.
Dave
Dave
jsc4484's picture
jsc4484
You can always sllep in the Aft cabin.
LOL Good luck!!!!!!!:)
FAIR WINDS & FOLLOWING SEAS
Jeff Costa
S/V KAIROS Hull #0235
