I am looking at a 1990 Catalina 36; one of the 3 cylinders apparently is "dead"; cost of finding parts, etc is very high.
Any suggestions on type of replacement engine,i.e., Yanmar, Westerbeke, Beta, etc.
If anyone has replaced a Universal Model M25XP, any issues with stringers, etc being redone?
Charles Lapp
Looking for a Catalina 36 or 34
South Shore, Long Island, NY
Charles E. Lapp, III & JoAnne Lapp
Class Sea "M"
1990 C36 MK1.5
Sail # 1053
Great South Bay, Long Island
Peconic Bay, Gardiners Bay
Eastern end of Long Island
Charles, the Universal diesel engine in our boats is a marinized Kubota tractor engine, and non-marine Kubota components are typically available at (so they say) reasonable cost. Are you a member (small 'm') of this Forum only, or are you a paid-up Member (capital 'M') of our association, the C36IA??? If you're a paid Member, then you have full access to our incredible library of technical articles, accessable from the drop down menu on the C36IA home page. Our past Mk I technical guru wrote a fine article on removing and overhauling the engine you're considering. Have a look there.
Larry,
Thank you; I just became a "paid-up" member and will do further research
Charlie Lapp
Class Sea "M"
1990 C36 MK1.5
Sail # 1053
"Marinizing" is essentially the conversion of the cooling system. In both applications, the internal high-pressure cooling is the same closed anti-freeze based system. The only thing that changes is how the heat removed from the guts of the engine by this internal coolant is itself dissipated: either by airflow through a radiator (the tractor), or by water flow through what we call a heat exchanger (the boat).
Beta Marine is a popular repower option as they will mostly fit without too much fuss - there is an article in the Tech section about repowering with a beta. If your adventurous, you could get new head, pistons, cylinders , gaskets for <$1400 - and rebuild it your self with "tractor" parts. Search ebay with "kubota D950". Depends on why you lost compression - head gasket, valve - or rings. Head gaskets are cheap, but by now you would probably have water damage,
I believe the M25XP is a D950 engine.
Another great resource is Stu's engine wiki over on the c34.org site. It has tons of info on many systems that are common between the models.
good luck -
Les
