Steering Failure
Sailscloud9
Steering Failure
Was out on the Bay a few weeks ago wind picked up (white caps) and my steering started acting up. On trying to back into slip lost control (a lot of play in steering. Contacted Edson and they sent me a check list. On inspection it was a failure of the 3/8" fiberglass bulk head where the the Edson bracket attaches at the stern under cockpit. A ~4" section og the bulk head broke off leaving the cable very slack, hence the steering issue
Has any one had this happen to them. 3/8" seams a little thin for a mechanism under such stress. Does Catalina have a fix for this? Sent a question to them. No response yet
I am thinking of having a reinforcing plate made.
Can you tell the forum your hull number, year and C36 model you have? (Maybe add it to your signature)
I've been a member for the past 2+ years and don't recall any similar failures. A picture or two would also help.
The Edson manual gives specs for the amount of cable deflection. (I think it's something like 1" max for a 12" unsupported length but double check my memory). Have any idea what your's was before failure? It's  easy to over tension the cable if care is not taken.
