Has anyone rewired the mast???? and installed spreader lights into the spreaders them self instead of a for deck light
FAIR WINDS & FOLLOWING SEAS
Jeff Costa
S/V KAIROS Hull #0235
Jeff Costa
Theme by Zymphonies
Hi Jeff,
I rewired my mast last year. I added spreader lights in addition to the fordeck light. It was not complicated at all. I will admit, I added the spreaders and a tv antenna later using a pull string I installed when I did the mast rewire. If I can help, let me know.
David Edwards
Bridgeton, NC
C36 MK I hull # 11
S/V Starting Over
How did you pull the wires out at the bottom of the mast? Is there an inspection plate ? Mine is covered with a vinyl covering that I would have to remove to look.
Mitch
1986 Catalina 36 MKI
S/V "Blessing"
Kema, TX
Hull: #584
M25 w/ Oberdorfer Conversion
