Has anyone used a setting other than 18 degrees (9.2 pitch) on a 15 inch Max-Prop (3 blade)?
18 degrees seems to be the recommendation from PYI but I am curious to see if anyone is set at another blade angle to dial the boat in.
Jack
Solstice
Hull #1598
Lake Texoma
I have the same prop and did try 20 degrees one summer. As I could only get up to 2500 rpm at WTO (wide open throttle) I have the m35a for the diesel and it would over heat if I ran it to fast as it was working it to hard. So I hope this helps. 18 degrees is in my mind the correct setting also as it is where it is set now.
Randy
Thank you Randy for the help.
Jack
Solstice
Hull #1598
Lake Texoma
www.texomasailing.org
Just as a "close out" post...
The prop is now installed on the boat.
18 degrees on the 15" 3 blade "Classic" was the setting I used and it was spot on. I am getting the same speed in foward (read same speed at a cruising rpm) as I was with the fixed prop. I can say the reverse is night and day difference with the Max Prop. Not all, but a very significant amount - estimate 90%, of the prop walk was eliminated along with addition of much more bite/power.
I have not been able to sail the boat yet so I can't speak to the sailing perfomance of the prop.
Thanks again for confirming the setting.
Jack
Solstice
Hull #1598
Lake Texoma
