material watertanks
Siler Starum's picture
Siler Starum
material watertanks
What are the exact material details of the white plastic watertanks and BW holding ?
Is this PE, HDPE or something else?
I want to do something to the weak and micky-mouse construction of these tanks by "welding" reinforcement strips on the top, make the vent connections bigger and fit a decent inspection cover.
Even with static pressure caused by a full forward water tank the aft-tanks are deformed like a balloon and now even causing the inspection cover to leak as the rubber O-ring is pushed out and filling the bilge whilst the vent is normal open and overflowing when the tanks are full.
(from previous old posts I read that it seems that this abnormal phenomenon became an issue as normally to be accepted by many users - similar as the tiny venting of the BW holding tank which gives always problems when pumping the head contents to the tank)
Durk Nijdam
S/V "SILER"
Stavoren - Holland
Sojourn's picture
Sojourn
Hi Durk,
I believe Ronco made the tanks for the early Catalinas.  Here's ther website.  I used on of their tanks to replace my holding tank in 2004.  I works fine, I have not replaced by water tanks their still holding up.
Regards,
Lou
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
Sojourn's picture
Sojourn
Lou Bruska
Sojourn
Eldean Shipyard
