How to clean interior cushions?
benethridge's picture
benethridge
Hi, everyone.
How do you clean your interior cushions? (Mine have mildewed somewhat.)
I've read somewhere that the best way is to remove the foam and put the foam pieces into a pool that's being chlorinated. (The chlorine removes the mildew.) However, I worry that the chlorine will break down the foam and ruin it.
Someone said to take the fabric to a dry cleaner.
What are your thoughts on this? Have you ever done it successfully before? What works for you and what doesn't work?
Ben Ethridge
1984 MK1 Hull# 263
benethridge
To answer my own question, I took these to a professional furniture cleaner. I found him on the Better Business Bureau website ([url]www.bbb.org[/url]). He steam-cleaned them with a special machine and applied a mildew inhibitor. He was experienced with inteior boat cushions. They smell great now.
Ben Ethridge
1984 MK1 Hull# 263
Ben, thank you for sharing the problem and the solution.
