I usually do not remove the fresh water impeller over the winter. During the last two years, however, the impeller fins stayed folded and water did not pump when we started the engine. We had to replace the impeller. Some time later the replaced impeller looked like new. Would turning the engine over several times before launch allow the fins to unfold or do most of you take the impeller out during winter storage?
Richard #1347
1994 C36
Richard
1994 C36 Tall Rig M1.5
Waukegan Harbor
Lake Michigan
Richard, didn't you answer your own question? If the blades get "set' the pump doesn't work. It's also good practice to re-learn impeller replacement techniques on a regular basis and to assure that you have spare impellers. We have a spare shaft with a new impeller, ready to go, all the time.
Richard,
I've read in several places that the non-toxic antifreeze most owners use is bad for rubber impellersas it tends to harden them. What I normally do is to take the impeller out of the pump after the engine is winterized, and put it on the nav table along with the keys. In the spring I reinstall the impeller and it works perfectly. Just a thought.
I have never taken out the impeller over winter on my 35BC engine and have never had a problem in Spring.
Gene Foraker
Sandusky Yacht Club
Sandusky, OH
1999 C36 #1786
Gypsy Wagon
Ditto,
I do not remove my impeller over the winter. Unless you sail in an area with a lot of silt in the water, or forget to open the seacock, the impeller will last a long time, thanks to modern polymer technology.
Turning the engine over by hand or with the starter motor before you start it in the spring is never a bad idea, as it pumps the oil around, and give the blades a chance to lose their set, so that they will be able to pump water when called upon to do so.
Dave
Ballena 1995 Mk II #1445
Thanks for the replies even though there is no agreement. Maybe the early April cold in Waukegan is also a problem. My local dealer never takes them off his boats. The sure way I guess would be remove.
Richard #1347
Richard
Waukegan Harbor
Lake Michigan
