Glow plugs
Coast Rider's picture
Coast Rider
Glow plugs
My universal 25 engine is hard to start. Takes more than a minute. I'm pressing the glow button about 45 seconds now. Is it time to change plugs ?
Joe Lucido
1986 Catalina 36
Hull # 0625
M-25 Universal diesel
Oceanside, CA
That's normal with the stock installation, because of the voltage drop from the wires running all the way back to the cockpit switch and then back to the engine (it is, after all, a high current draw item).
If you haven't done so, try installing a relay to bypass this loop, as in this article form decades ago by the then-tech editor (the late Bob McCullough).  Its an easy, inexpensive modification (on our boat, we screwed the relay to the wooden bulkhead, but this meant we had to detach it anytime we removed the bulkhead for access, so probably better to find somewhere on the engine to bolt it).  On our former C36Mk1, it reduced the glow plug time from almost a minute to around 10 seconds:
www.catalina36.org/members/technical/upgrades/glow-plug-solenoid
