C36MKII Exide Nautilus NG-4D Battery replacement
9 posts / 0 new
mtnguy
My batteries have finally given up the ghost after almost 10 years of service and I am looking to replace them with the original Exide Nautilus NG-4D batteries that came with the boat. The problem is that Exide does not seem to make these batteries. The original batteries are labeled: Exide Nautilus Commercial starting/deep cycle. 1400 MCA, 400 reserve. After a lot of internet searching I could not find a battery that approaches this spec. I did find a forum talking about Exide making these batteries just for Catalina. Does anyone have any information about these batteries?
Dave
smcguckin's picture
smcguckin
When I needed to replace my 4D batteries (and they were an interstate battery)...I elected to go with 4 6V deep cycle "golf cart" batteries. To do that I had to remove the "battery trays" Catalina installed ( 2 wood screws each) since the 2 golf carts are a tad longer side by side than one 4D battery so they would not fit in the tray. I simply put in some web strapping for each battery to hold the new batteries in place. I also had to make a couple of jumpers since you have to put 2 of the 6V batteries in series to get 12 volts.
I did the same on my C30....The golf carts are, in my opinion, far better deep cycle batteries than anything you can buy in a 4D size. I also have never had an issue with starting the diesel engine using them either.
Good luck,
Sean
Sean McGuckin
Mahalo Lou
C36 #1748
Mystic, CT
The golf carts are also a lot easier to lug around.
mtnguy
Roger on the easier to carry around. I have done a lot of research since I posted my question and have come up with the following: The Exide Nautilus Gold starting/deep cycle commercial batteries are in fact commercial batteries with the screw posts. Same construction on the inside as commercial. The commercial batteries are used mainly for large cross country commercial trucks to start their engines and to power their Auxiliaries while parked. They are commonly called dual purpose batteries and are supposed to be able to withstand discharges of up to 50% repeatedly without damage. Since my batteries lasted almost 10 years and served my purposes well, I think I will buy a commercial grade 4D battery and put some marine screw post adapters on the terminals. The commercial grade 4D batteries from Deka have almost the same specs as my old Exides and cost a lot less than the dual purpose Marine. $130 vs $250 each. I'm in the process of replacing all my 12 volt lighting with LEDs and other than my electronics I don't power anything else with my batteries. I guess I could run my reefer but that would run down even the best of Deep cycles in short order.
If they hold up for another 10 years, Ive done good.
[QUOTE=mtnguy;649]I guess I could run my reefer but that would run down even the best of Deep cycles in short order.
If they hold up for another 10 years, Ive done good.[/QUOTE]
With 2 4Ds you have almost 400 AH in your house bank (assuming you have a separate reserve emergency bank, formerly mis-called a start bank). The fridge uses 60 AH per day. With almost no other loads, with your new LEDs, you cold go two nights on the hook without having to recharge (by limiting yourself to a 50% discharge). Hard to understand the concept behind your approach, but I guess those without fridges learn to live with it. Those with them usually use them and learn how to manage their electrical systems.
10 years is great, but I don't connect it to lack of use. That's what batteries are for, to use.:)
billta
Stu,
I just replaced my 4d's with the Deka commercial 4d. This is the same battery that West Marine has listed as their Sea Volt dual purpose wet cell. My local commercial auto/industrial dealer had them in stock so I went the easy route instead of the golf carts and the redesigning of the battery trays. In my research, I looked at the Exides also. Go to Exide.com and pull up their battery specs, and you'll see the Nautilus NG-4d 4d's listed with these specs, CCA @ 0= 600,CA @32@75amps= 850, RC min @ 25 amps = 250, and rated @ 160 AH. The Exide commercial battery Com-4d-p is rated higher for cca and ca's at the same levels, but is not rated in AH's. The Deka was rated about the same as the Exide commercial. My dealer said the commercials are what he puts in most boats around here. I also called the dealer in Annapolis that put in my original 4ds, and he said that's all he puts in the boats he supplies there. He doesn't put in the true deep cycle ones unless requested, saying the commercial ones do the same job, are rated higher, and are cheaper. I'm not so sure this is true, but at least now that I have replaced mine, I'll be able to tell exactly how long they'll last. Next time I can make the decision to do differently or not. Hopefully after at least 5 years.
Now, I also found wet cell true deep cycle batteries at Mid State Battery in Connecticut that are true deep cycle and rated at 205 AH's. They were just a bit more in price, but the shipping was prohibitive. These Mid States are the same as the Defender deep cycle ones in their catalog. Defender's are expensive, plus the shipping.
The discussion underthe heading "Batteries" also in this thread gives all the pros/cons of golf carts too.
By the way, I still have not found the correct maunal for my model of the Link 2000 you helped me with last fall. I must have the original Link 2000 monitor, that they improved upon very quickly, and destroyed all evidence of the old one. Thanks again for your help, and all the info you provided.
Bill Taylor
Heel'n Good #1612
Washington, NC
pierview (not verified)
I was able to get good replacement batteries from NAPA Auto at a lot less than what West Marine was asking.
Gunkholer 1889
I seem to get 4-5 years my 4-d's. They seem to still have life but when new I can site for a solid 2 days at anchor without charging. I now can only get a little over a day. I do pretty much abuse them in the we anchor out about 90 nights a year and do a lot of charging in the 40-80% range. I'm not sure 6volts or agm's would get me much,plus my boatyard pulls and reinstalls them over the winter so I don't have to manhandle them. I do buy my batteries from them as the price is pretty comtpetitive.
Gunkholer - Have you ever equalized your batteries? Se: [url]http://www.amplepower.com/wire/eql/index.html[/url](link is external) That's one of the reasons that happens, plus chronically undercharging batteries or leaving them somewhat discharged. If you don't have a battery monitor, at least for your house bank, I strongly urge you to invest in one. The amount of power that goes back into batteries takes a long time because of battery acceptance - they take less as near full charge. Try downloading and reading the ample power primer at [url]www.amplepower.com[/url](link is external), technical documents. You should get a lot more from your batteries.
