Can sambody thell me wath te freon type is in the refrigeration
we have a catalina 36 from 1993
is it R12 or R134a
is a replacement off te system with Waeco CU55 en VD07 possible ??
mvg Jan Borst holland
is it R12 or R134a
Theme by Zymphonies
The early 1990s is when the change from R12 to R134a took place as it was mandated to be done by 1995, so it could be either one. Two ways to tell which refrigerant you have:
Enclosed is a picture of the two styles.
Tanks for the responce Nick
have a picture from the compressor
The service line (vertical tube attached to the compressor) appears to have a threaded dust cap on it, suggesting that it's an R12 unit. Not unheard of, but 23-years is a long time for a refrigeration unit to be still fit-for-duty. Might be time to replace rather than repair. The Waeco CU55 and VD07 should be very close in size and capability to what you currently have. But measure things at least two times to make sure.....
For what it's worth. I put a brand new Alder Barbour unit in 3 years ago and it has Schrader valves on it. I would go by what the tag or manual says and not by the valve type.
