1988 Mk 1 refridgerator replacement
Lanealoha
Ours is dead, I had the compressor 'repaired' in Mexico, it lasted about 36 hours and died again.  Any recommendations for a replacement?  Ours is port of the galley sink, I believe it is an Engel brand that they no longer make...
David Lane
S/V Grace
88' Catalina 36'
Oxnard, Ca
Army Sailor
I have posted this a bit recently, but 2 years ago I replaced my adler barbour with a novakool 201 LT4 version.  It comes pre-charged and is a pretty easy install and replacement for the original units.  Its also pretty efficient on power and will freeze everything if you turn it up past halfway.
Lanealoha
Great thanks.  Is it a top loader I assume?  Will it be a drop in replacement?  Thanks
David Lane
S/V Grace
88' Catalina 36'
Oxnard, Ca
Army Sailor
It turns the current built in cooler or fridge into a refrigerator by putting a compressor out in the port cockpit locker and running two lines to the small freezer compartment that mounts in the cooler.  You also mount a thermostat unit it the cooler and run the wire to the compressor unit, usually through the same holes as the refrigerant lines.  As you already had a refrigerator and compressor unit in there, it should be a basic replacement.  I did have to increase the size of the holes for the refrigerant lines but then I sealed them with expanding waterproof foam after it was all done and working.
