Sea Water Pump
Roger
Sea Water Pump
My original Sherwood pump (1996) is leaking a little, rather old for a rebuild. Would replace with an Oberdorfer but not in stock anywhere and no date when will be available. I found this pump: does anyone have any knowledge/ thoughts on this pump. Thanks.
#JPR-WB7108 JMP Marine Westerbeke Replacement Engine Cooling Seawater Pump (Replaces Westerbeke 42175, 042175, Sherwood G908, G903, Universal 302648, 302837)
1996 C36 Mk II, #1545
Frankfort, MI
Brazen
Online
Last year about this time I bought the JMP pump from Woodline Parts online. Price was $385 or so.
My Sherwood started weeping badly but it did continue to cool the engine. The "complete rebuild kit" I had onboard turned out to be missing the seal that failed.
I needed a replacement quick and the JMP is working fine, the Sherwood is now rebuilt as a complete spare.
Denis
Brazen Article #1925
2001 Catalina 36 MKII
rimwithbrim's picture
rimwithbrim
Pump for the M35(B)?  I just ordered the OBD n202m-908 yesterday. No troubles finding it in stock online.  The N202m-837 is a kit with mounting hardware and was also in stock several places online.
check here if this is the one you're thinking of: (I called a verified before ordering yesterday)
pumpsandpartsonline.com
marinepumpdirect.com
Cheers
Justin Brim
S/V Koan
Port Orchard, WA
2003 Catalina 36 MKII
M35B
EUREKA's picture
EUREKA
I replaced the original Sherwood with the JMP, some five years ago, No problem at all, Pump is full bronze.
Regards
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Home port Barcelona (Spain).
TomR's picture
TomR
Bought this pump years ago from Big Blue Ocean Marine and it seems to be an exact replacement for the Sherwood & cheaper. I've had no problems with it working for at least 3 seasons. Go for it
Tom Runiewicz
ObLaDi ObLaDa
Hull #1998
North East, MD
Roger
Thanks for the reviews, just purchased the pump
Frankfort, MI
Roger
Follow up question, I received the pump, WB7108, I noticed there is no mounting gasket with the pump. Dealer said JMP doesn't have mounting,gaskets. What did you guys do for a gasket, does OEM gaskets work or ? Thanks.
Frankfort, MI
I buy a sheet of gasket from the auto store and trace the base of the pump, cut and punch holes where the mounting bolts are using a paper punch. Use a very thin gasket. Nothing special about this paper gasket.
