Mark 1 anchor windlass
9 posts / 0 new
MississippiSkip
Hello folks. I want to install an electric anchor windlass on my Catalina 36. It's a Mark 1 and it doesn't have one currently. I've seen the Sail La Vie discussion which is on a different vessel. Does anyone here have experience on an older boat like Trilogy?  Thank you for your kind assistance.
Skip Kuzel
S/V Trilogy, Catalina 36, Mark 1
Hull #53
Pass Christian, MS
Not sure if hull #53 would have the glassed-in spot inside the anchor locker for a vertically mounted windlass, but my Mk 1.5, 1991 model does.  Without that you are probably looking at a horizontal model mounted on the deck behind the anchor locker.  There are some inexpensive (relatively) Chinese ones you can source online.  700 w was the recommended size from the manufacturer.
Sojourn's picture
Sojourn
Skip,
I have a MK 1 model and I installed a vertical windlass on my boat.  See the photo attached.  It is straight forward and the windlass can handle both chain and nylon rode.  I have 120' of 5/16" chain and 200' of 9/16" plait line.  I have other pictures, too large for this website, I'd be happy to share with you.
Lou Bruska
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
Image icon Anchor Windlass - Sojourn 004.JPG1.25 MB
Online
Lou.
I would be interested in your pictures as well. gwtw36@outlook.com
Online
Lou. Thanks for the pics!
J.R. Seago
Lou
I to have a MKI 1984. I would love to see pictures of your installation if you would be so kind. Especially inside the V Birth. Did you add a dedicated battery? If so where?
Please email
jrseagojr@gmail.com
J.R. Seago
Seago'er
1984 MK I
Dana Point, CA
MississippiSkip
Thank you for your quick replies!  I can see a way through this project successfully now. Things such terrific help.
Skip Kuzel
Hull #53
Pass Christian, MS
Lanealoha
We mounted a horizontal windlass, would have preferred a vertical but we also didn't want it intruding on the v berth.  Took some mods but worth it, and clean, no designated battery, no problems.  We've anchored out at the Channel Islands here in Ca, sailed to Puerto Vallarta and back, anchoring all over the place and in all kinds of conditions up to 40kts of wind and no problem, we use a bridal so the windlass doesn't have to support any load.
Sorry, I dont know why the pictures load side ways!?
David Lane
S/V Grace
88' Catalina 36'
Oxnard, Ca
Link to image/post in the forum with photo of the vertical windlass setup in the pre-Mk II models: https://www.catalina36.org/sites/default/files/forum/IMG-2621.jpg
