Cabin side windows on C36
9 posts / 0 new
richie30's picture
richie30
Our windows on the sides of our Catalina 36 coach house are quite crazed.
I have replaced the ports as well as the hatches with success.
Any advice on replacing the side windows? They look like a fairly easy removal if you cut around them and gently take them out and get a pattern made to replace, but I would love to hear from anybody who has done it. Best!
Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
Rich-
If my memory is correct, do a search on this site and there will probably be several postings. Cleaning up the original adhesive, masking the inside of the window, and building a wooden support mounted on the stanchions with arms pressing against the plexiglass were crucial points. I don't recall the recommended adhesive to use.
Sikaflex 295 in white or black is the only version that that manufacturer recommends for sticking acrylic to aluminum if you are doing hatches as well, but their recommended primer was worse than useless on the aluminum (like a black paint that peeled right off). 295's efficacy on acrylic to fiberglass with no primer was OK, but I screwed up by NOT building the wood frame across the stanchions. (I thought i applied sufficient even pressure with a length of 2x4" and trucker straps, but it left gaps in several places leading to multiple efforts to reseal due to ongoing micro-leaks. I will still need to apply more Creeping Crack, but it leaves stains on the outside that are tough to remove.)
I further messed up by finding that the original SS screws were so short that 95% of them had not actually engaged the fiberglass, so I did not have the plastics workshop drill the many holes around the edges of the acrylic for me to replace the original 1/4" screws with 1/2". Doing so would have solved my self-made problem by pulling the acrylic in tight to the fiberglass, but then building the wooden framework also would have done so.
The original porthole acrylic was OK for templates (mark the port/starboard and inner/outer sides for the plastic supplier) even though I broke a couple during removal. Scraping off the original glue is tedious, but doable and you can buff off the last bit with a power tool.
Careful masking tape around the final adhesive application and the use of firmly placed wood pieces jammed against the new acrylic should lead to good results over 24 hours, even WITHOUT buying and pre-drilling new screws all the way around each piece. (If you are doing this while the vessel is in the water, the pieces of wood could pop out if she is rocking in waves over the 24-hour drying time.)
NOTE: afterwards you have to be super careful to never let Windex get close to the acrylic. I have a couple of spots where we've allowed something that must have been similar to Windex drip over the new acrylic and crazed it again. The crazy does not go all the way through the plexiglass, it just affects the outer layer.
rjwilson's picture
rjwilson
Catalina uses Dow Corning  795 Silicone Building Sealant.
Bob Wilson
S/V Morning Breeze
2003 Catalina 36, Hull 2122
York River Yacht Club
Williamsburg, VA
TippingPoint
I removed my side windows this spring, I let them air out a few days the used Sikaflex to reseal, make sure you have thinner or mineral spirits and plenty of wrags ready to clean when you reseat.  Probably one of the easiest projects I have had on my catalina.  I know this sounds silly, make sure you use tape to mark the orientation of each window and ensure you do not mix them up :)   Another note, I used Sikaflex on the EXTERIOR not inside.
Ed Dewsnap
Marion, MA
1984 Catalina
thisoldfish
Ed,
Did you build something to apply pressure to hold in place?
How do you get the old windows out?
S/V Escapade
2003 C36 MK2
Hull 2148
Standard rig/wing keel
Universal 35 BC
Brazen
Boat Works has a good tutorial on the process. The fixed ports are frameless so 3m VHB tape provides the holding property and Dow 795 is the flexible sealant around the edge.
When I replaced all the ports on my previous Catalina I bought the replacements from sailboatowners.com. They can also be made by any decent glass shop.
The 3m VHB tape is very strong, use care placing the port. The 795 is messy, have plenty of paper towels and tape off everything other than the seam you need to seal.
Denis
Brazen Article #1925
2001 Catalina 36 MKII
thisoldfish
Helpful video--- thanks.. doesn't look like a terrible job.. (famous last words!)
S/V Escapade
2003 C36 MK2
Hull 2148
Universal 35 BC
Jgreagori's picture
Jgreagori
Rich,
I am in the same situation with the large salon port windows. Ours are cracked also on the verge of falling out. We were in the Bahamas when i noticed we were getting water through the cracks in the plexiglass, super glue works wonders for sealing them up. I did some research thinking of purchasing and cutting the plexiglass, but have elected to go to Catalina Direct. Made the patterns from their supplied material and purchased the kit. I'm waiting now for the weather to break here in New Jersey until I can pull the old. The jig they send plans for to hold the new ports in place until the caulk hardens looks interesting to build. CD has all the stuff. I let you know how I make out.
Serenity C36 MKII 1996 #1583
