Relocate RACOR to stb engine bulkhead?
Thurbersw
Hello - has anyone had experience relocating your RACOR fuel filter to the starboard bulkhead in the engine compartment, underneath the engine cover and above the oil dipstick check hinged panel? If so, did you run into any complications?
Specifically I'm wondering if the heat in the engine compartment might cause a problem.  The RACOR specs say maximum fuel temp for the filter operation is 190 deg F.  Any idea what temptation the engine compartment would get to?
I know the latest standards require that the RACOR bowl be changed from a plastic to a metal bowl for fire protection reasons.
Any advice is appreciated.
Scott Thurber
Gra-Sea
2005 Catalina 35 MkII Hull 2224
East Greenwich, RI
"Gra-Sea"
East Greenwich, RI
2005 C36 MkII #2224
Tall Rig/Fin Keel/M35B
rjwilson's picture
rjwilson
I changed the filter to a turbine unit and relocated it there a couple of years ago and no issues.  The picture shows part of the filter assembly, but you can see where it is mounted.
Bob Wilson
S/V Morning Breeze
2003 Catalina 36, Hull 2122
York River Yacht Club
Williamsburg, VA
Ours is located on the port side of the engine compartment near the muffler; probably the standard location for the MKII. We've never had an issue with heat.
Thurbersw
Just what I'm planning to do Bob.  What turbine unit did you choose?  I'm guessing the heat deflection shield under the filter allows you to have a clear glass/plastic bowl?
Thx Phil for your reply.
"Gra-Sea"
East Greenwich, RI
2005 C36 MkII #2224
Thurbersw
*Paul
"Gra-Sea"
East Greenwich, RI
2005 C36 MkII #2224
rjwilson's picture
rjwilson
I installed the Turbine 500 MA model.  I believe the heat shield is a CG requirement.
Bob Wilson
S/V Morning Breeze
Williamsburg, VA
Thurbersw
Thx Bob
"Gra-Sea"
East Greenwich, RI
2005 C36 MkII #2224
