Mattress topper
mikescheurich1@...
Mattress topper
Hoping to update the discussions from several years ago about mattress toppers. I'm not looking to replace the v-berth mattress. But a nice foam topper with a quilted cover would be perfect. Do it yourself is one option. But have any of you used any vendors that you would recommend?
Sojourn's picture
Sojourn
We use Tufted Topper; unfortunately, the owner retired and closed the business.
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
Sojourn's picture
Sojourn
Mike,
You might try the following:  Mattress Toppers - Boat Beds
Lou Bruska
Sojourn
Eldean Shipyard
mikescheurich1@...
x01203
We did this.  Got the 2" thick king size foam off Amazon, and it was a game changer!  Brought one of our Vee mattresses ashore, laid it on top of the foam and traced out the shape of the Vee, and then used an electric carving knife to cut it out.  Seemed a little small at first but after expanding for a day or so it was perfect.  Best $90 I ever spent!
https://a.co/d/bFqJYnv
If the link doesn't work (wonky on my mobile device) you can type in "Lucid 2 Inch Mattress Topper King – Memory Foam Mattress Topper– Bamboo Charcoal Infusion – Ventilated Foam – CertiPur Certified Foam"
"Luna"
2003 MKii
Standard Rig, Wing Keel
Hull #2160
Bristol, RI
mikescheurich1@...
Thanks! That's what we ended up doing as well. Worked perfectly and slept comfortably. Now we're trying to decide whether to buy a fitted sheet set from Catalinadirect.
