Tach
Roger
Tach
Can anyone recommend a tach replacement for my original tach (1996). Thanks.
1996 C36 Mk II, #1545
Frankfort, MI
Just a suggestion if you haven't tried:
If your tach is malfunctioning, try rotating back and forth the slotted plastic disc on the back. The disc is a variable potentiometer used adjust the RPM reading. Over time internal corrosion sets in but often be cleaned up by rotating the disc with a screwdriver. This has worked for me on two boats.
Roger
Thanks for the response, done all the adjustments but tach is not working.   Catalina Direct says tach is not available. Wondering if there is another source.
Frankfort, MI
Sojourn's picture
Sojourn
Hi Roger,
I have Universal M25-XPB engine.  It is a replacement engine.  At the time I changed out my old control panel to Universal's Admiral panel.  According to my parts manual, the tach is part #036590.  I checked the number on the Universal/Westerbeke website.  The price is $139.50.  The picture does not show an engine hour meter in the tack.  You should call Westerbeke and clarify that and get dimensions.
Hope this helps.
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
Roger
Thanks for the info.
Frankfort, MI
EUREKA's picture
EUREKA
Hi,
I replaced mine with a Teleflex gauge, working perfect since then. Engine Universal M35. Hope it helps
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Home port Barcelona (Spain).
