Mast step
Khan
Mast step
Any buddy seen something like this is it fixable?
1983 C36 hull #119
MDR CA
lavrendios
Greetings to all,
Time for a large spring cleaning. I discovered under the fore cabin sole a cord which leads to the fore peak, passing under the central water tank. The invisible end is spring loaded. Does anyone know what that is for? Thanks.
Lavrendios
S/y RIPPAPAÏ,
C36 MK1, tall rig
Year 1993, # 1286
Not sure what I'm looking at on the MK I. Your feet are at the mast step, and from there the image captures the shape of the hull moving towards the bow? Is the "dark rectangular wood" a compression post extending from the cabin sole to the cabin roof, meaning the mast is stepped on top of the cabin?
We have several chords running through various hull areas on our MK II. I assume these are to pull additional cabling. Rather than an invisible spring at the end, might you be feeling the chord stretch?
