M25XP Coolant water pump part numbers
Fudsdad
Can anyone please supply the part numbers for the coolant water pump including bearings and seals on a Catalina 36 M25XP please?
You may be able to find the manual on line with an internet search. If that fails, call a Universal/Westerbeke dealer. I've used Hanson Marine in Marblehead, MA.
I'm assuming you are talking about the coolant circulation pump and not the raw water pump. If so, Check out these folks;  https://www.kumarbrosusa.com/kubota/water-pump.html(link is external)
I believe the M-25XP engine is called a D950 as used in the B7200 tractor.  If so check out;  https://www.kumarbrosusa.com/kubota/water-pump-d950.html(link is external)
I have not had to put one in but  phone call to those chaps might help. It's about $40.00.
Fudsdad
Many thanks.  Sid at Kumar was very helpful and I got my pump.
Great ! Nice to know we have another supplier.
Lanealoha
I'm in need of a new water pump, I'm wondering/ just wanting to confirm that the part you found worked out good for you?  I have an 1988 , 36 with the m 25 xp as well....If the one listed in the above post worked its insane what I see it for on Catalina Direct vs. what is available elsewhere...
David Lane
S/V Grace
88' Catalina 36'
Oxnard, Ca
