Prop size 3 blade for 36 MK11 with M35 diesel 1995
John MacDonald
looking for original 3 blade prop size on 1995 36 MK11 with M35 diesel
"15 R 9" is stamped into our prop powered by an M35B....so 15" dia. with a 9" pitch
Absolutely's picture
Absolutely
Ours is also a 15R9. 1998 mkII originally with the M35B.
Dale and Nikki
1998 C36 mkII SR hailing from Poulsbo, WA
1989 C25 TR/WK
John MacDonald
Thanks. Found a 15 x 9 3 blade in my spare parts and wanted to verify. Changing out my current folding prop due to barnacle fouling and subsequent engine vibration. curious to compare performance.
Siler Starum's picture
Siler Starum
what is the ratio of your transmission? If this is not original anymore the standard 3-blade 15R9 is not matching.
Durk Nijdam
S/V "SILER"
Stavoren - Holland
John-
Your transmission may be the same as ours: Hurth ZF10M. If so, the "A" ratio is 1.79 and "B" ratio is 1.86. I believe A means the forward gear ratio and B means reverse..
