Balmar alternator getting to hot.
True Wind
I have a Balmar 120amp alternator with a ARS5 external regulator and J10 belt. I have the alternator throttled down by adjusting the belt load manager setting. So when it first starts spinning cold it puts out 90amps. But in a matter of minutes the temperature sensor tells the regulator its to hot and reduces output to around 20amps then the amps will eventually climb back up and then go back down again.  Anybody here have this similar problem and if so how did you fix it? I've moved the alternator both farther away and closer to to engine and no difference. I extended the bilge blower exhaust hose closer to the alternator without any improvement.  Hmm
David
2003 M35BC
2003 Catalina 36
Ray Taylor's picture
Ray Taylor
Hello David,
I have the same system on our boat except that I have a 100 Balmar alternator and a Balmar battery bank balancer.  I’m interested in how your problem is resolved and have a couple comments.
To start I don’t monitor my alternator performance while underway.   But do monitor the battery system and solar performance at anchor.
With this I’ve noticed a couple simple things.   The amount the system charges is based on how discharged the batteries are.    So for example I’d expect the alternator to charge at a greater rate after starting the engine then reduce a few minutes after.   Similarly our solar charging provides way more amperage to the house bank in the morning after a nights electrical use.
I’m certain you know that our fancy external regulator controls charging to the batteries well beyond temperature.
I use similar adjustments that you described for belt, temperature, and overall amperage output.    Even though I have both battery and alternator temperature indicators I don’t know how to determine if they are actively reducing the alternator output.  I just assume they are working properly.  It sounds like I need and additional gizmo in the system that provides more info. Or maybe look at our battery monitor while motoring…
I’d also add that tension adjustment on the serpentine belt is difficult.   Too loose/too tight each has problems which can include overheating.   I’ve learned to be extremely fussy with belt tension and alignment.
Good luck resolving your problem and I’m hoping to learn more about our own system in the process.
Ray
Ray & Janice Taylor
"Mizu"
Hood River, Ore.
#2113 2002 TM
