Oversized anchor on standard bow roller?
16 posts / 0 new
sidthekid's picture
sidthekid
Hello All,
Currently, I have a 35 lb CQR (see photo) on our standard MK II bow roller.
With 50 feet of Hi Test Galv 5/16 of chain and 100 feet of 5/8 3 strand line, we have held "fast" in several serious overnight blows "pitching" in several of the wide open bays in the mid-Chesapeake, which has primarily a mud and sand bottom.
I am considering a new anchor (Rocna or Spade) with more chain and nylon rode.
We are planning on doing the ICW (more current) and perhaps some of the Caribbean (deeper depths).
Main questions are:
Should I consider an oversized anchor, such as a 44 lb Spade or equivalent?
Will the standard bow roller be adequate without any modifications?
Has any one adopted an oversized anchor which "fits" on the bow roller and can be secured in place while underway?
Thanks in advance for any comments or recommendations. This site has been an very helpful resource to me and many others!
Bill & Barb
s/v Northern Lights
2002 Catalina 36 MKII #2086
Rock Hall, MD
Northern Chesapeake
Sojourn's picture
Sojourn
Bill & Barb,
Changing the anchor to more modern design is good idea.  Your current anchor has 30-1/2" length on the roller.  That's plenty big enough to go to 44 lb. Delta, the 44 lb. Ronca is maybe too long and the bail is going to be an issue.
My boat was modified to added a roller by a previous owner, it's on the short size, about 24".  I use a 35 lb. Delta.  As for rode mine is 120 feet of 5/16" G-43 chain and 200' of 9/16" plaited line.  My secondary anchor is a 25 lb. high tensile Danforth anchor with 30 feet of 5/16" G-43 chain and 270 feet of 9/16" plaited line.  Never needed to use it.  We have cruised on the Great Lakes for the last 14 years averaging 6 weeks out and 880 nm round trip.  Anchoring about 40% of the time.
I would recommend a chain length about my length for a couple of reasons.  In most weather conditions and anchoring locations (30 kts. of wind or less and 20-25 feet of water) we on an all chain rode.  Deeper or windier we let out some nylon rode.  Most modern anchors have hole for attaching a retrieval line.  I have a bail there and it holds a short line that secure to the bow cleat to secure the anchor while under way.  I also use it to attach retrieval line and buoy.  I use a 12" round buoy with a block on the bottom and 40 feet of 1/4" line with a 3 lb. SS weight to help center it right above the anchor in most depths I anchor in.  Even shallow depths it's not far from the anchor.  It lets us and our neighbors know where the anchor is and can be used to retrieve the anchor as necessary.
When on an all chain rode, we use a CS Johnson chain hook and 25 feet of 1/2" laid nylon line.
Whatever you decide, safe anchoring.
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
Bill...
What do you mean by "secured in place while underway"? When I bought my boat (2nd owner) the PO had a short wire attached to the bail and the anchor to secure it when underway. I removed it because, in extremis, I want to be able to drop the hook right away and not mess around with any tie downs.
I have a short line in the anchor locker with a hook that hooks into the chain and is tied off so prevent accidental releae but that's a quick releasse.
Sojourn's picture
Sojourn
What I mean is simply an 18" 3/16" line tied to bow cleat keeps the anchor secure in the roller. A separate light wire eith a snap shackle secure the chain inside the anchor locker.
Lou Bruska
Sojourn
Eldean Shipyard
sidthekid's picture
sidthekid
Thanks for your comments and questions. What I mean by secure in place is....keep the anchor on the roller with some type of tie down. There is another post where the primary or storm anchor was lashed in the v-berth, and a day anchor was kept on the bow. I want to avoid that. Will definetly get more chain and line. The old 35lb CQR still holds it own - rated third overall - in an updated Practical Sailor test March 2020. (https://www.practical-sailor.com/sails-rigging-deckgear/in-sand-the-spad...) Leaning to keeping the CQR at this point. Don't want to get stuck with an "oversized" anchor which either does not fit well on the bow roller, or leads to damage of the furler drum or bow roller.
Bill & Barb
s/v Northern Lights
Rock Hall, MD
Northern Chesapeake
alfricke's picture
alfricke
This is a topic near and dear to all who spend many a night at anchor! I used a CQR for years, and put up with an occasional drag here in San Francisco Bay and up and down the coast (mud, sometimes kelpy or grasses). Finally upgraded to a Rocna 20 (44 lbs). Zero problems since, sets very quickly and unmistakably. I have a stainless swivel shackle that automatically keeps the anchor from coming up over the roller backwards. A must for single handers. I use 100' 5/16 high tensile backed by 200' nylon rode. The chain hook line is permanently attached to the big cleat in the anchor locker for easy deployment. 100' of chain keeps me on all chain in most situations. A small brass clip on a piece of short stuff,securely attached to a u bolt in the locker, keeps the anchor from inadvertently deploying in bouncy conditions. I keep the windlass loose so I can just kick the anchor over in a hurry when over my spot. The small winch handle for the windlass is in a pocket out of the way on the side of the locker. It has a small attached line as well for obvious reasons. Finally, I installed a wash down pump under the forepeak berth that leads into an attachment inside the locker, with a short piece of hose permanently there. This set up has worked well for me. The two things to be careful of are: 1) Don't let anything get caught up in the chain as it is going in or out and 2) don't let the chain pile up too high when bringing the anchor up as it can jam the windlass...a nasty situation I know from bad experience!! I really do not think the extra weight of the oversized anchor makes any difference and sleeping is great. The Rocna fit just fine on the existing roller set up, though care must be used to prevent the shank from injuring the roller furler as it comes over the roller.
Al Fricke
S/V Jubilee San Francisco Bay
Catalina 36' MkII  #1867
Universal 35-B
Lanealoha
I pretty much run a similar set up. I had to do a bit of mod to make my setup work on an 88' Mk I version as far as windlass... But back to the point, I use 140' of 5/16 and 200' of 8 plait on a 45lb mantus anchor.  I also use a stainless swivel at the chain anchor attachment as well.
Last year while anchored out at Santa Cruz Island a family pulled in later in the day and jumped in their dinghy and were dragging something back and forth around their anchorage.  I asked them what they were doing, and they were dragging a grappling hook to look for their anchor and chain.  Seems a few nights earlier they were anchored and the capt.  woke in the middle of the night and realized they were adrift and 1/2 way to Anacapa Island!  Seems the rope to chain splice failed for whatever reason and they lost their ground tackle.  Good thing the capt woke up and noticed he was adrift, could've been an ugly outcome.
So....this has led me to the thought of some kind of anchor buoy or something so if it were to happen I wouldn't lose the whole kit.....
Sorry for the adrift....
David Lane
S/V Grace
88' Catalina 36'
Oxnard, Ca
alfricke's picture
alfricke
Adrift while asleep, a thought that will guarantee no sleep! Rope to chain splice failure is the failure of the skipper/owner....can't happen if done properly and of course inspected periodically. Except when being forced to anchor in rocks, I hate the use of an anchor buoy. One more thing to go wrong, get fouled up on the rode, wrap the prop, hassle with getting it properly deployed, tap tap tap the hull near your head on a windless night, need for careful retrieval while pulling anchor in the pitch dark trying to get under way etc etc etc. Sure are a lot of variables when it comes to anchoring....I think a lot depends on the actual use and location of the boat. CQRs have worked fine for me, but they will definitely drag in a few grassy bottom conditions around here (SF Bay) and slowly drag in the soft muck of the Sacramento delta when afternoon winds get to 25-30 kts. My Rocna handles these conditions much  better. The CQR worked great for us all through the Channel Islands and years in Mexico. Never dragged.
Al Fricke
Universal 35-B
I need to replace my anchor chain and I'd swear the old chain is 3/8ths but it seems the majority of posters use 5/16th. Some articles I've seen recommend "BBB chain"... (bend before break) but I have not seen any reference to that on the postings. Any recommendations?
How do those of you who have hundreds of feet of chain store it in the anchor locker.... seems to small to hold all that plus nylon rode.
Lanealoha
I have room to spare.  I could put more in if it wasn't a weight concern.  I'd prefer all chain.   Its possible that my older 88' Mark I has a bigger locker it sounds like....I'm 5' 10 and it's not quite chest deep.
^^^Good points sir.
David Lane
S/V Grace
88' Catalina 36'
Oxnard, Ca
sidthekid's picture
sidthekid
Chuck et al,
re: your question about 5/16 chain. I have a Maxwell VW800 windlass and the specs for anchor chain size are as follows;
THE MAXWELL VW 800 WINDLASS IS DESIGNED FOR CHAIN UP TO A MAXIMUM CHAIN SIZE OF 8MM (5/16”) SHORT LINK CHAIN.
On all chain systems a smaller size High Tensile Chain may be used to save weight.
This spec may account for the frequent use of 5/16 chain.
to "et al". Thanks for all of your detailed comments and suggestions. I've learned a few more things about anchoring as a result. And now, it is all captured in this searchable knowledge base!!
I'll post our ultimate decision later in September....
Bill & Barb
s/v Northern Lights
Rock Hall, MD
Northern Chesapeake
sidthekid's picture
sidthekid
Update on anchor/rode project. Had to be completed over the winter months and wait for early spring for on the water anchoring opportunities.
Thanks for everyone’s comments regarding my questions on upgrading my anchor, rode, and chain.
Good news is that the Rocna 44lb anchor fits on my original bow roller, but I did have to get a larger bale. Purchased a Garhaurer Boom Bale BB-4, which is the correct height, but a couple of inches too wide. I addressed this by using longer clevis pins and a bunch of washers to get a good fit.
I am able to deploy and retrieve the 44lb Rocna with about the same level of effort as the original 33lb CQR.
One concern I had was the anchor may tilt in the bow roller in windy conditions, since the bow roller is wider than the shaft of the anchor.
To account for this, I’ve attached a 5’- carabiner to the bale with a short line secured to the cleat inside the anchor locker.
I also wrap a four inch rubber tie down around the bow roller and anchor which secures the anchor and keeps it from moving and tilting.
I do realize this setup is not ideal for an emergency anchor drop but the trade off is a more secure anchor when underway.
Components:
Rocna 44 lb galvanized anchor
Suncor Stainless Steel 5/16" Anchor swivel 8599 mll
200' of 5/8" 8 Plait Rope (white)
G4 HT Anchor Chain ACCO 5/16 120 feet
The Rocna anchor and additional chain provide additional security when anchoring in tidal areas or open bays.
I hope my follow up adds to the "online searchable database" for future reference.
Bill & Barb
s/v Northern Lights
Rock Hall, MD
Northern Chesapeake
Sojourn's picture
Sojourn
Bill,
Looks good.  One suggestion is to add a small bow shackle to the top hole.  That will allow you to added a trip line quickly, you should ever decide to use one.  I am leary of swivels, especially in salt water.  Hard to inspect for corrosion.
Lou Bruska
Sojourn
Eldean Shipyard
Foshay
Nice looking set up.  we also have the Rocna 20kg, and the only issue we have is that the "arm" hits the underside of the furling cage when being deployed / retrieved.  Makes for some very awkward moves in very confined area.  Wondered if any one else has this issue, has a solution? C36 Mk 2, 2004, #2173.
http://mei1970.org/saillavie/c36Album/index.php?album=Windlass%20And%20A...
Foshay, please visit my online album to get an idea as to how I solved the problem of anchor shank coming in contact with the fuller.
Contact me if I can provide answers.
Sojourn's picture
Sojourn
Hi Haro,
Having looked at you addition of a down switch to the anchor locker, I notice a potential problem.  In designing a circuit, that has both power (the windless) and control (the pedals), it is generally a good idea to separate the two parts of the total circuit.  In this case, the high amperage circuit should not be part of the low amperage control circuit.  In order to separate them cost is, of course, added.  That cost is in the form of a solenoid control box (see Diagram enclosed).  The reason is  to separate the two to protect the foot pedals from potential failure in the form of worn out contacts due to arching of a partially activated depression of the pedal.  Catalina's interest was to keep the cost to a minimum, hence one pedal and direct wiring.
In the one photo attached my windless, Maxwell VW1000, was installed by me.  The old Mark I boats did not have a provision for a windless.  I installed it aft of the anchor locker.  In the other photo, the additional wiring is for a radio operated remote key fab style devise.  Note the small gauge wires going from the pedals to the control box and large gauge wires going from the box to the windless.
What you have works, but leaves room for improvement.
Regards,
Lou Bruska
Sojourn
Eldean Shipyard
PDF icon Maxwell VW Windlass Wiring.pdf623.65 KB
