I have an old Seaward Hillerange 2 burner + oven, which I think is now called a 2172 on my C36 mk2
I would like a new gas oven, anyone know which models (any make) will fit in the same spot using the same lugs?
Nigel
Nigel Frith
If not now, when?
This winter we installed a Force 10 stove model 63251 (which, in their catalog(link is external), is called "American Standard" size) to replace the GSI CNG stove/oven in our 1985 Mk I #466. It was a perfect fit -- didn't even have to move the gimble brackets. See this thread for more discussion:
www.catalina36.org/forum/technical-discussion/propane-stove-0?fbclid=IwAR1HF0F35G9isXJSEKpdq-aGWHuOTKa6wFJTKt5p7xycw9lCq3VThtX_uO0
Thanks for the advice
Nigel Frith
If not now, when?
Matthew,
I saw the photo of the Force 10 stove. I appears to not having a cutting board or more correctly, not able to have a fitted cutting board. While the C-36 galley has more space than most boats, losing that work surface is a big loss. What if anything you have done. I'm not in a hurry to change out a functioning stove, but who knows what the future may bring.
Regards,
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
We have a cutting board on ours, which I made out of 3/4" teak boards. It was actually the cutting board that I had made for our old stove (which fit into the top). There is a sort of track on the left and right sides of the Force 10; I routed a small recess on the left and right edges of the cutting board and it slides right in and is held firmly in position. Sorry, no picture handy; will try to take one next time I'm onboard.
Thanks.
Lou Bruska
Sojourn
Eldean Shipyard
Cutting board photo
