How to remove stern berth front shelf ?
bdeliman
This is the shelf that sits directly behind the engine compartment. I have removed 5 screws that are across the width of the shelf behind the wood dowels, and 2 smaller screws on the right side top, by the opening to the main cabin. I have also removed the 2 screws holding a plumbing "U" behind the engine. Any help would be appreciated.
Bill Deliman
Bill Deliman
Vivacious 2
Atlantic Highlands, N.J.
I think the set=up has changed over the model years, and on later models Catalina made it easier to access.
On our 1985, I have reconfigured it on our boat to make it easier to remove (all the screwws are now accessible from the outside), so I can't recall exactly how I did it the first time.  However, I seem to remember that I had to remove the bulkhead that seperates the galley from the aft cabin to get at all the screws, as they were internal at that point.
Bill-
That shelf is held down in our boat (2005) by two rubber snap clips: the same ones used to secure the engine cover on the other side of the cabin bulkhead.
