Water Tanks on 36 MK 2
richie30's picture
richie30
I am thinking about we plumbing the water tank valves.
Mine are original, (1998) three of them and really hard to turn on or off.
I have also thought about putting the two aft tanks on one switch. Would that make sense?
thanks
Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
Sojourn's picture
Sojourn
Hi Rich,
Each tank should be on it's own valve.  As the valves are bunched together they won't help with line leakage, but will help with weight distribution.  Water weighs 8.35 lb per gallon.  If your boat list slightly to the starboard with the tanks full, I'd drain the starboard tank first.  If not, the forward tank is like having a football linebacker standing on the foredeck.  Drain that one first, then the starboard second and finally the aft center tank.   That's my take. Of course, you're probably not racing so these small weight differences don't really matter.
Lou Bruska
Sojourn
C36 MK 1, Hull #495
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
Sojourn's picture
Sojourn
Hi Rich,
Lou Bruska
Sojourn
C36 MK 1, Hull #495
Lou Bruska
Sojourn
Eldean Shipyard
Sojourn's picture
Sojourn
Hi Rich,
On my first post, I forgot to mention the most important reason for have each tank on its own valve.  If one of the combined tanks leak, in effect, they both leak.
Lou
Lou Bruska
Sojourn
Eldean Shipyard
I replaced the valves on my 2002 C36 but found it a pain in the neck to have to open up the sette cushion/hatch cover every time. On my boat (at least)) I had a fire extinguisher in a cut-out under the stove. I moved that to the starboard side and put a 3 valve distribution bar in the cut-out. Much handier.
Someone on the site did this years ago and there should be more details in the tech library... that's where I got the idea from.
