Fresh water pump suggestions
Ray Taylor's picture
Ray Taylor
In preparation for a future project I need to relocate the water pump on our 2002 Mk2.   Since the pump is original equipment I’m considering replacing it with a new pump.    I’ve heard the old pump model has been discontinued.   Has anyone thats installed a new pump recommend a replacement?
Ray
Ray & Janice Taylor
"Mizu"
Hood River, Ore.
#2113 2002 TM
I think when we last replaced ours, maybe half a dozen years ago, we went with a Shurflo 2GPM pump.   Seems to be ample capacity.  There are lots of choices in the market.
kerry boden's picture
kerry boden
I had to replace mine and found the best product was from
http://www.pumpsandpartsonline.com/(link is external)
Oberdorfer make a perfect replacement of really good quality and are very helpful.
If you search the archives you will find a lot of info.
cheers
Kerry Boden
Ray Taylor
Thank you
Ray & Janice Taylor
"Mizu"
Hood River, Ore.
#2113 2002 TM
Ray; A you questioning the engine raw water pump or the house water pressure pump ?
Ray Taylor
I should have been more clear.   I'm replacing the potable water pressure pump.
Thank you,
Ray
Ray & Janice Taylor
"Mizu"
Hood River, Ore.
#2113 2002 TM
Ray;
 A Flo-Jet 4405-143 is what we are using. ​It's working out very well after 4 years of operation. About $135.00
https://www.defender.com/product.jsp?id=151034(link is external)
