Jib Sheet Replacement
I'm replacing my jib sheets and in the C 36 owner's manual on the rigging page it calls for 7/16' line at 45' for "jibs" and 55' for "genoas".
Can anyone explain why there would be a difference and why the genny would call for 10' more?
dlincoln3's picture
dlincoln3
Maybe they're assuming you would take the sheet through the turning block at the stern quarter and then up to the winch on the genoa but not with the jib.  Or maybe they're accounting for the thickness of the sail wrapped on the furler.   I have 55' sheets on my genoa, and  iwould not to have less than that.  I replaced my sheets 2 years ago.  I went from the 1/2" line that was on the boat when I bought it and replaced it with the recommended 7/16".  I wish i would have stuck with 1/2".  It seems like it was easier to handle and seated into the self-tailers on the winches better.
Don Lincoln
"Nancy Lynn"
LaSalle, MI (Lake Erie)
Universal M-35AC
The clew on a genny is going to be significantly more aft than on a stock jib.
Thus, the lazy sheet (i.e., the one not in use on a given tack) needs to  reach back that much further to the clew after passing around the mast.
Ergo, longer sheets.
dlincoln3's picture
dlincoln3
That makes sense!
Sent from my SM-G950U using Tapatalk
Don Lincoln
"Nancy Lynn"
Universal M-35AC
Zefyros
Because the Genoa has a longer foot than the Jib. You will need to carry the lazy sheet, further aft on the boat on the working tack side.
Yianni Spiropoulos
Zefyros
1988 C36TR HULL # 896
Duh.... obvious when you think about the lazy sheet... thanks guys!
