Replacement Battery Charger
richie30's picture
richie30
Any recomendations for a replacemwent battery charger? I currently have a Promatic 30-3 (original to my 98 MK2) It is still wolking fine, just not sure how long it may last, so I'm being proactive.
Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
EUREKA's picture
EUREKA
We changed ours, some years ago, with a Mastervolt 3/50ah.
Regards
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Home port Barcelona (Spain).
bakerha's picture
bakerha
We also upgraded to a mastervolt 6 years ago.  3/40 amp - my house bank is 360AH.  I read somewhere that charge capacity should be ~ 10% of bank capacity or larger.
_____________
Harold Baker
S/V Lucky Duck
1989 C-36 mkI TR/WK M25XP
I purchased a Sterling Ultra (ProMariner) 40A. You should size it to at least 10% of your house bank. Be sure and get a charger you can program to get the optimal profile (and not just switch changes for preprogrammed profiles). I bought mine from Compass Marine. The owner there is a past owner of a Catalina 36 and publishes great web site to aid diy folks fixing their boat. Marine how to.com Les
Pgutierrez's picture
Pgutierrez
I replaced both 12 V (80 pounds each) starter batteries summer 2015.  My 2000 Catalina 36 hull1897 has the 40 amp original Pro Mariner charger. Last weekend I decided to add water to the lead acid batteries. Each took 1/2 gallon of distilled water. Marina mechanic is suggesting charger is cooking the batteries and replacement of charger.  I think he is right...what do you think???
peter g
2000 C36, MK2, Hull. #1897
Something is cooking them. Either the charger or alternator. What is the float voltage set for, and what do you measure with a VOM?
