Forward Facing Sonar
9 posts / 0 new
Pgutierrez's picture
Pgutierrez
Is anyone using this technology?
peter g
2000 C36, MK2, Hull. #1897
Siler Starum's picture
Siler Starum
Online
Yes, but not on a Catalina...:-))
Durk Nijdam
S/V "SILER"
Stavoren - Holland
Pgutierrez
And what were your thoughts on it???  Brand? Ease of use? Would you buy one???
peter g
True Wind
I am using it on my C36. I'ts actually manufactured by Airmar but labeled by B&G and Simrad. It works great, It's basically it's a transducer that is angled in a forward manner.
2003 Catalina 36
McFly
I have B&G Zeus 2 with a NMEA2000 backbone, so plugging in another sensor is relatively easy.  I was considering forward scan for the empty spot up in my hull.  I anchor in some gunk holes with skinny water.  It might be nice to have an alarm go off if I was approaching some kind of obstruction or anything else not on the chart.  It is a bit pricey, about $500.  I certainly think its relative to the forum and worthy of the question.  I think it comes down to the kind of waters you cruise in.  If you're in skinny, unfamiliar water frequently, I think it's great technology.
Siler Starum
Online
Hi Peter,
The forward facing sonar I am referring to is installed on a very big pleasure yacht, make Farsounder, never used and a real waste of money.
This kind is all beyond our Catalina-hobby and not relevant for this forum.
Durk Nijdam
S/V "SILER"
Stavoren - Holland
True Wind
The forward looking sonar does not connect to a NMEA 2000 network. It is installed directly to the back of the B&G MFD in sonar #2 connector..
2003 Catalina 36
On one Panbo review the guy broke the transceiver before he could test it. A stray chunk of wood destroyed it. As was said earlier it has an angled face that sticks out about 1.5” below the hull.
Sojourn's picture
Sojourn
Some arithmetic might called for here.  B &G website indicates the device can see about 8x the depth in good conditions.  Soft mud and rocking type of bottom may defuse the signal and reduce reliability to 5 times the depth.  Now assume your in 10 feet of water best view 80 feet, reliably maybe 50 feet.  Speed counts, a boat travels at 100 ft/minute/knot or 1.67 ft/sec/knot.
Example:  Traveling at 3 knots in 10 feet of water.  The obstruction is 50 to 80 ahead.  Time to impact = distance/1.66/knots
At 80 feet, (80/1.66)/3 kts = 16 seconds  At 50 feet ahead  the time is 10 seconds.  All this assumes your staring at the screen, reconize the object, plan a new course of action and execute.  At 5 knots of speed the times are reduced by by 40%.  Your new reaction times at 80 feet the time is 9.6 seconds, at 50 feet the time is 6 seconds.
Unless your actually trying to survey the bottom, its probably a waste of money.
Lou Bruska
Sojourn
1985 C-36 MK1 hull #495
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
