Hello all --
I'm cleaning my bilge out, and removed the Rule pump I have been using. I unscrewed the screws holding it down and have had leaking from those holes. Just a few drops, but persistent. I think it would be 1 or 2 cups or so over 24 hours. It can't be leak from outside -- the boat is on the hard. Is it reasonable to plug these up with 5200 or epoxy? I don't know where the water is coming from.
Thanks for any help.
Peter L
Peter Lundquist
s/v Rafael
1998 Catalina 36
Hull #1669
Salem, MA
Bill,
Are you saying that the water is rising up counter-gravity through the holes from the area of your keel. Have you checked the torque on the keel bolts, do you have a severe catalina smile?
Ed Dewsnap
Marion, MA
1984 Catalina
Peter, did you ever find out where the water was coming from? That is what I would want to know. Do you have large blisters on the bottom that could be seeping to the screw hole? Did the leaking ever stop. I would not seal the hole with water seeping out.
Tim
Tim Askew
S/V Allure
1990 Catalina 36 Hull # 1079
Std Rig, Wing Keel, M25XP
3 Blade Auto Prop
Elizabeth City, NC
Hi guys
The leak stopped. Still not sure what was going on. After it stopped i filled the holes with 5200. Hope I’m not ignoring something important.
Thanks all
Sent from my iPhone using Tapatalk
Peter Lundquist
s/v Rafael
1998 Catalina 36
Hull #1669
Salem, MA
