MKII fixed cabin windows
Wally-1840
hi all,
Does anybody know of a supplier for the fixed cabin side windiws? It seems the person I used for my stb. Windows no longer makes them. I don’t see them on the Catalina Direct site.
Wally
"Onanne"
​Lake Champlain
rtrinkle's picture
rtrinkle
Did you ever find a supplier and specs?  I’m assuming you are talking about the windows on the side of the coach roof. I have a cracked one, stbd side, it’s the window that goes starts above the chart table and ends in the aft cabin.
Robert Trinkle
Universal M35A
Kinsale Harbor Marina
Kinsale, VA
You might try Cruising Concepts (www.cruisingconcepts.com).  I bought a complete set of replacements for our Mk1, which upgraded from the old aluminum framed windows.  I assume they could provide a replacement for MkIIs...
Wally-1840
Yes, I called Catalina Direct and they pointed me to the Catalina Yachts parts department in Largo, FL. They said there are slight differences in the openings and I’d need to send them a template and they’d make them for me. If you do a search, you’ll find my post on our window replacement project. It wasn’t super easy, but not too daunting either. If I do it again, I’d most likely do one window at a time as both makes for a long day.
Wally
"Onanne"
​Lake Champlain
Wally;
I helped install a window replacement job on  a Pearson 36 a few years ago and used these folks. They were most helpful but you did have to send them a template or one of the old windows.
https://www.estreetplastics.com/Default.asp
