Windlass installation
bakerha's picture
bakerha
I'm looking at installing a windlass this year prior to a cruise and have found several great articles on that subject.  But, all that I have found refer to running wiring from the house or dedicated batteries located in the saloon area. Something like 30+ feet (round trip) of 2ga to 0ga depending on the equipment. I am wondering why no one puts a dedicated battery in the bow locker?  Seems that the wiring would be much simpler and shorter.  A smaller charger could be added there as well to keep that battery topped off when needed.
What am I missing?
_____________
Harold Baker
S/V Lucky Duck
1989 C-36 mkI TR/WK M25XP
HCJ's picture
HCJ
I wanted to go that route on my previous boat, but decided against it because it would add even more weight to the bow. After adding the roller furler, 200 feet of chain and another 300 feet of nylon rode plus the weight of the windlass itself I worried the prop would come out to the water if I added a battery to that mix!
Henk Hiensch
Mar Y Sol
1984 Catalina 36
Hull# 379 Universal M25
Ladysmith, BC
Your point is well taken and a good idea. One Catalina 36 I saw when shopping, had a seperate battery and charger for windless operation. The AGM battery and charger were  located at the bottom of the closet in the forward 'V' berth.
Talisman
It’s not necessary.  I linked my windlass to the engine start battery amidship and it has worked well for 15 years.  You are not going to use the windlass without running the engine anyway
Enrique
Talisman
1998 36 MK2 Hull #1673
Tall Rig Wing Keel
M35BC engine
Old Saybrook, CT Summer
South Glastonbury, CT Winter
two-rocks
Somewhat rare, but I do run my windlass without the engine. I like having the option.
With that said, I only have 2 batteries (on a 1-2-both switch) - and solar - always leave it on both.  Factory installed windlass, run to the same batts.
I have a battery in the bow for the windlass and an ACR to charge it. The PO installed it. A battery is light compared to 120’ of chain or a water tank ( I don’t have the water tank ).
TippingPoint
Bakerha,
I also plan on installing a Windlass and have every intention to install the battery under the v-berth,  I am curious, what make windlass did you decide on and where do you plan on mounting it.    I ask because I am considering mounting inside the anchor locker.
Ed Dewsnap
Marion, MA.
Ed Dewsnap
Marion, MA
1984 Catalina
bakerha's picture
bakerha
Thanks for all the replys.  One thing I was considering is the weight of all that copper wire running to the bow from the game table seat area where my house batteries are installed.  My starting battery is further aft so didn't think that was a good option. A smaller Deep Cycle battery in the bow would only  weigh in at about 55lbs.  And the reduced wire size and weight will nearly compensate for that.  I agree that adding the windlass, chain, battery, etc does start to add up.  But, Like Leslie, I don't have a bow water tank and that helps.
The windlass I want to install is the Maxwell RC8-8 but still deciding whether to go with the Capstan model or not. The capstan would be great for raising my jib but that is only once a year and I'm not sure I want a hole in my anchor locker lid. The windlass would be installed on the small shelf inside the locker allowing that lid to close and the motor to be mounted inside the v berth behind that back panel.  There are some great articles on this web site for those.
_____________
Harold Baker
S/V Lucky Duck
