Head Shower
richie30's picture
richie30
Head Shower
Has anyone ever modified the shower in the head to allow better stand up showers?
This is one of our main concerns with our 36. Would love a proper shower, perhaps even just mounting the shower head permanently and sealing the surrounding area better? Any ideas welcome.
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
Richard,
I felt the same way. I left the faucet/shower combo alone in the sink, and added a handheld showerhead with its own mixing valve. You can adjust the temp, and then just push the mixing valve in to turn it off. Pull it out to turn the shower back on. Worked great. Took a bit of sweating some copper tubing and elbows. Used Tees off the existing hot and cold supply lines under the sink.
Nice job, Tom. I like it. Very classy.
richie30's picture
richie30
Thanks Tom!
I think I will do this.
I also have to replace the curtain and rod.
I will sorce that out!
Take Care.
Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
Rich -
We did pretty much all of the same mods that Tom did (I keep telling him if he ever gets on our boat it will look rather familiar!):
  • separate shower spray head and valve (I think these were Scandvik).  Sping clips hold the hose in place when not in use.
  • replaced sink faucet with single lever faucet (also Scandvik), which saves water.  (Also mounted a teak CD caddy repurposed as a holder for shower soap and shampoo, etc.);
  • added an angled teak lip on bottom of the head compartment door (to prevent the spray from running under the door and into the salon);
  • redid the shower seat so that its pinned onto dowels (rather than screwed in), so that its readily removable to clean underneath on occasion;
  • replaced the original sump pump with an outlet (an offset through-hull fitting) installed at the bottom of the sump pan connected to a hose that is routed through the bilge, thence under the port forward settee, thence back into the head compartment to a Whale gulper pump mounted behind the small door over the toilet, and thence (after a vacuum break loop) to the seacock under the shower seat.  This allows the sump to be completely emptied.
Pictures of all these mods are attached.
We desisted from using the shower the first year we owned the boat because there was no shower curtain.  But then we discovered it was totally unnecessary, and thus we don't have one (which would just take up a lot of room).  The head compartment seems to have been well designed by Catalina (I believe) NOT to need one, and as long as the cabinets are closed, no spray from the shower goes anywhere that it shouldn't.  The head compartment dries out very quickly, and if anything the occasional shower keeps it cleaner.
We also, when cruising, frequently make use of camping-style solar showers, which we suspend when ready over the hatch for the head using a spare halyard.  They work quite well, particularly when we haven't made use of the engine for a while and thus there's no hot water in the heater tank.
- Matthew
Mother Ocean's picture
Mother Ocean
Hi Matthew,
Where did you source the ​offset thru hull-fitting in the sump pan?
Tim
Tim Askew
 S/V Allure​
1990 Catalina 36 Hull # 1079
Std Rig, Wing Keel, M25XP
​3 Blade Auto Prop
​Elizabeth City, NC
Don't recall where I got it, probably a WM store. It's in their catalog, "MarineEast L-head barbed drain, #1867761
Mother Ocean
Thanks, got it. I like the idea of being able to completely drain the pan.
Tim
Tim Askew
 S/V Allure​
​3 Blade Auto Prop
​Elizabeth City, NC
