Cable length for pedestal wiring
ROAM's picture
ROAM
Can someone tell me the aprox. routed cable length from the pedestal guard to electrical panel. Might I find space in flex conduit of
the existing wire run and is it accessed under the starboard outboard panel(s) in the quarterberth ? I will be running the wind instrument and AIS cables aft and the Multifunction display NEMA 2000 cable forward I'm thinking. At the 1" pedestal guard  I imagine it would be best to utilize the unused tube for new wiring. Guidance appreciated
 Greg
Greg
ROAM
C36 MkII 2001
SF Bay
rjwilson's picture
rjwilson
If I recall correctly I ordered 30 ft of cable and that covered the length.  There are 3 conduits running aft and there will be room for the cable.  You should plan on removing the hanging locker in the aft stateroom to get better access to the conduits and the opening into the hell hole under the electrical panel.
Bob
Bob Wilson
S/V Morning Breeze
2003 Catalina 36, Hull 2122
York River Yacht Club
Williamsburg, VA
ROAM's picture
ROAM
Thanks. Wow, that seems really long. But how it ends up sometimes
Greg
Greg
ROAM
C36 MkII 2001
SF Bay
rjwilson's picture
rjwilson
That is the length that I ordered.  I know that I didn’t use all of it, but what you are going to dine is it’s not a straight run back.  If I recall there was 5 90 deg turns in the hanging locker section alone.
Bob Wilson
S/V Morning Breeze
Williamsburg, VA
ROAM's picture
ROAM
That is the right length. Thanks
Greg
Greg
ROAM
C36 MkII 2001
SF Bay
Greg - I can't give you a length estimate, but will give you the heads up that depending on how much electronic stuff you are planning to have in the pedestal-mounted pods -- and the size of the connectors -- you may also have to consider swapping the 1" pedestal guard for a 1-1/4".   We had to do this on our boat the last time we did an electronics upgrade, because the connectors simply wouldn't have fit along with all the other wiring (particularly with a bend in the tubing to negotiate).
We're currently doing another upgrade of electronics, and happily the newer stuff -- such as the 3G radar -- seems to have significantly smaller connectors and cables.
