12 digit hull number for a 1984 C36
SailorJo
I own a 1984 C36 hull number 379. It does not have a 12 digit hull number. It was imported into Canada in 1995 from the US. I now have an American who is interested in purchasing the boat and re-importing it back into the USA. We cannot find a 12 digit hull number anywhere on the boat. As it stands this means it cannot be imported into the USA. Is there anything I can do about this?
Owner of a Mk 1 C36 Hull # 379 commissioned December 1984.
Fin keel, standard rigging.
Boat is based in Nanaimo, B.C., Canada, where you will find one of the finest cruising areas in the world.
Sailor Jo,
I'd suggest contacting Catalina Yachts.  At one time they had an individual file (yes, a manila file folder!) on every boat, with all the details about the boat. On a factory tour many years ago, I got a look at "my" file, and it contained all sorts of stuff, including letters I had sent to them! They might  be able to help.
Some repair on the transom must have obscured it as my 83 has the HIN in the normal place.  There should be a duplicate hidden in the hull that the factory know about.  I also have documentation numbers printed inside just forward of the 2” waste discharge valve.
Les
Lenny DeMoranville
Look behind the plate over rear cockpit hatch (at boarding ladder) thats where it usually is
On my '91 it is engraved in the gelcoat just below the toerail on the starboard side at the stern.  Not very visible.
