RIB Storage
Talisman
RIB Storage
What is the best way to store a RIB for the winter.  Fully inflated, deflated or partially deflated?
Enrique
Talisman
1998 36 MK2 Hull #1673
Tall Rig Wing Keel
M35BC engine
Old Saybrook, CT Summer
South Glastonbury, CT Winter
I would think dry, out of the sun and clean is most important. If you fill now with cold air you may stretch as it warms up so I would say partially inflated
Maine Sail
Our 2001 AB RIB (16 years old) has ben stored inflated, upside down on elevated saw horses, then shrink wrapped/covered her entire life (I have my own ShrinkFast gun and use scraps). It has in fact only ever been deflated once or twice. I only need to add air maybe once per year. At -15F it gets a bit soft, but it is still plenty inflated so as to not have a deformed shape..
We leave ours inflated, suspended from the ceiling in our barn. We've had carpenter ants chew a hole in a PVC inflatable when it was stored on the floor of a garden shed. (They ate an airconditioer cover too- so they must be attracted to PVC). Basement storage is ok, but takes up a lot of room. I don't think it matters much whether it's inflated or not.
Talisman
Thanks everybody.  Clean, dry, inflated and covered from the sun sounds like the consensus.
Enrique
Talisman
Tall Rig Wing Keel
M35BC engine
