Galley Sink / Drain / Facet
richie30's picture
richie30
I have read a few of the posts re replacing the galley sink. Does anyone have any suggestions and
or photos?
Failing a complete replacement, perhaps just replacing the facet and drain assembly might be acceptable to the "skipper". I also have a "nickel sized" hole just in front of the facet, not sure what it was for or how
to fill.
Any suggestions would be appreciated!
Richie
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
Pelican
Hi Richard,
Our boat is a 1989 MkI with the original interior, galley and fixtures. I am sure the sink is available through Catalina Direct, if not, phone the factory. The faucet could be one of many used over time. Ours was manufactured by Grohe I believe. The good news is many modern faucets will fit. The bad news is gaining access to the underside of the sink and faucet with tools is difficult. Very little space between the sink and the back of the settee. Some have cut a service port in the back of the settee to do this work. Others have removed the entire sink. The nickel sized hole in front of the faucet was used for a salt water spigot that was pressurized by a foot pump I believe. Search the C36 Forum, it has tons of info and options on faucet and sink issues. Also the C34 site has good info as well. Hope that helps a little.
Cheers,
PO
Paul O,
S/V Pelican
1989 Catalina 36  Mk I  #894
Oceanside, California
[quote=richie30]I have read a few of the posts re replacing the galley sink. Does anyone have any suggestions and or photos?
Failing a complete replacement, perhaps just replacing the facet and drain assembly might be acceptable to the "skipper". I also have a "nickel sized" hole just in front of the facet, not sure what it was for or how to fill.
[/quote]
  This post from us -- https://www.catalina36.org/comment/59281#comment-59281 --  on an earlier thread has a photo of the replacement sink we installed in our galley, and details of the make and model number.
  It was about half the price of the replacement stock double sink, and we've come to really appreciate the ease of using reasonably-sized single sink rather than two tiny ones.  (Yes, probably less ideal when sailing in terms of preventing water from slopping around, but we don't tend to do much elaborate stuff in the galley while sailing the boat anyway).  We can actually put our large pots inside it when cleaning or filling them -- imagine that!
  You can install pretty much any kitchen faucet into it; we replaced the original faucet a number of years back on the old sink with the Scandvik galley faucet that now appears in the photo on the right hand side of the sink which is easier to use (and saves water) by having a single lever rather than having to manipulate a hot and cold faucet.  But in hindsight, we should have installed one of those kitchen faucets that also converts into a sprayer hose -- that would have been a handy thing.
  The little faucet on the left side of the sink in the photo is for filtered water -- it runs pretty slowly so we gave it its own faucet (because it was frustrating when we were drawing water for washing dishes or other uses).  The little spout on the top right is for the icebox drain, operated by the foot pump.   We tend to supplement our icebox with 10# blocks of ice when cruising, to cut down on battery drain, and the melt water can be used as well for dishwashing.
[quote=Pelican]
PO[/quote]
If you are not removing the entire sink, one way to get access is to remove both the drawer unit under the sink as well as the side drawer unit.   I just removed the latter this weekend for access to something else, but its not difficult and makes it a lot easier to work on things.  The side unit has maybe 8 screws fastening it to the cabinet; they are hidden under wooden bungs, which you can drill out to expose the screw heads.
  Without this, would very much agree with Paul O -- the contortions to access the faucet are, um, challenging.
cvcv
[quote=Pelican]
PO[/quote]
We have that spigot as well, but as mentioned above, its used on our boat for the drain from the ice box.   Not sure if this was the original design.
