Went to harbor for a work day ,wash down and to beat the heat.While washing the deck I find my wind indicator at the bottom of the mast.(&*^%$)birds.I order a new one from Defender $53.49(^&*%#)
I'm looking for advise on what tools and any tip when to replacing the windex.
Lou
Willful
1989 mark1 hull #889
Oceanside ca.
New wind indicator
Sun, 06/30/2013 - 05:30
#1
New wind indicator
If I recall, you'll only need a screwdriver. The 'mast' of the Windex goes into a hole in the base, and is held in place by a set screw. I believe it's a slotted screw (should be illegal), so I'd take both a flat bladed and phillips up the mast with you.
I never go up the mast without screwdrivers (slotted and Phillips), crescent wrench, pliers and my Leatherman (includes knife), and WD-40.
Joe & Patti Worth
"Tehani"
1999 C36 MKII #1810
I ended up with the same problem this winter, windex is broken in half. Does anyone know which is the 'proper' replacement? I'd like to ascend the mast only once if at all possible.
thanks -
Tim Farrell
S.V. Kailua
C36 - 1986
Hull# CTY0678A886
When you say "wind indicator" do you mean the windex or the 3 bladed thing that spins and gives you wind speed? If the former, pliers and screw drivers but if the wire "mast" part is broken you'll need to take it down and manually bend it into the correct shape. If the latter, there is a set screw and I don't remember what sort of head it has.
when I bought a new windex vane this January I purchased one with a bird spike - a foot long rod extending vertical - should help keep big birds off..
