Those of you who use a strut zinc, what is the Diameter? Recently bought #1711 and need to replace the zinc.
Thank you!
Steve Steakley
SNOWBALL
1998 C36 #1711
Seattle,WA
Thank you!
Steve Steakley
SNOWBALL
1998 C36 #1711
Seattle,WA
Theme by Zymphonies
My boats a 2002 and the strut is 1"
I use 2" disk with one screw in the middle.
About Sail La Vie
my strut zinc (first installed this Feb) is a 2" with the screw thru the center. 33 years - no zinc.
Les
Steve - you should join us at the Catalina Rendezvous at Roche Harbor May 4-7. PM me and I'll hook you up with the organizer. I'm the only 36 but lots of 34's and 42's (33 boats total).
Les
One inch prop shaft.1997
Chuck Lennox
97 MKii Ventura Ca
Island Girl Hull #1611
Thanks for everyone's comments. We just purchased hull 1711 and will have the vessel recomissioned in about two weeks in Puget Sound. Les, thanks for the invite. Once we get the vessel in the water we will contact you for information.
Steve Steakley
SNOWBALL
1998 C36 #1711
Seattle,WA
I was once told that the stern rail and propeller shaft are the same diameter. 1 inch sounds about right.
You can use either an R-2 or R-3 anode on your strut. Both use the same diameter machine screw. The R-2 is 2 3/4" in diameter and the R-3 is 3 13/16" in diameter.
Clean bottoms are FastBottoms!
