Diameter of strut zinc
9 posts / 0 new
ssteakley's picture
ssteakley
Those of you who use a strut zinc, what is the Diameter? Recently bought #1711 and need to replace the zinc.
Thank you!
Steve Steakley
SNOWBALL
​1998 C36 #1711
Seattle,WA
My boats a 2002 and the strut is 1"
Online
I use 2" disk with one screw in the middle.
my strut zinc (first installed this Feb) is a 2" with the screw thru the center.  33 years - no zinc.
Les
Steve - you should join us at the Catalina Rendezvous at Roche Harbor May 4-7.  PM me and I'll hook you up with the organizer.   I'm the only 36 but lots of 34's and 42's (33 boats total).
Les
clennox's picture
clennox
One inch prop shaft.1997
Chuck Lennox
97 MKii Ventura Ca
Island Girl Hull #1611
ssteakley's picture
ssteakley
Thanks for everyone's comments. We just purchased hull 1711 and will have the vessel recomissioned in about two weeks in Puget Sound. Les, thanks for the invite. Once we get the vessel in the water we will contact you for information.
Steve Steakley
SNOWBALL
​1998 C36 #1711
Seattle,WA
Mikeg516
I was once told that the stern rail and propeller shaft are the same diameter. 1 inch sounds about right.
fstbttms's picture
fstbttms
You can use either an R-2 or R-3 anode on your strut. Both use the same diameter machine screw. The R-2 is 2 3/4" in diameter and the R-3 is 3 13/16" in diameter.
Clean bottoms are FastBottoms!
