Does anyone know how to remove the top of the chart table? I'd like to get it home to refinish it, but I'm not clear on how to get it off. Thanks!
Roy
S/V Godspeed
Port of New Bedford
Catalina 36 MKI
1983 ~ Hull #62
Standard Rig, Fin Keel
Roy
S/V Godspeed
Port of New Bedford
Catalina 36 MKI
1983 ~ Hull #62
Theme by Zymphonies(link is external)
It will require you to pull the drawers and then you should be able to see the screws which hold the chart table in place. At least that is the way mine was held in place. My boat is a 1990 MK1.5. You should add the year of manufacture to your signature, so going forward it could fine tune your request.
Great info and advice on the signature. Thanks!
Roy
S/V Godspeed
Port of New Bedford
Catalina 36 MKI
1983 ~ Hull #62
