Although I don't own a Catalina, I have frequently read your posts to learn about maintaining my boat. I am considering the purchase of a Universal 25-xpb 26 H.P. 3000 RPM motor to repower. I have read good and bad about this motor, and mostly about rough running through the RPM range, and high idle requirements.
I would be very interested in hearing about the pros and cons you can offer. Alternatively I am considering the Beta Marine 25 H.P. which is a 3600 RPM motor and the Westerbeke 35E which has 28 H.P. at 3000 RPM.
John
John,
Avoid the XPB even if the Beta costs more. And even if you have to redo mounts, riser, panel, etc.
The XPB has the raw water pump under the alternator, a really rotten place for it. It also usually comes with a crappy Sherwood pump. You're right, it runs rougher than blazes.
The Beta has superb reviews, great support, it's a Kubota block, Beta even helps tell you the tractor parts.
The ONLY place (that I know of) on the entire internet you can find XPB info is the C310 group on www.sailboatowners.com.
You don't need internet help with Beta, hell, the company will freely tell you all you need to know.
Good luck.
John
I repowered a Cal 34 with a Beta 25. Loved the engine and Beta's support. Very smooth running. Very plug and play install.
Chuck
Chuck Lennox
97 MKii Ventura Ca
Island Girl Hull #1611
