Fuel line hose size
Mark Gadson's picture
Mark Gadson
Fuel line hose size
I'm getting ready to install a new fuel line hose from the fuel tank to a new Raycor 500 MA Turbine fuel filter.  My 1995 Mk II has the M35A engine. Does anybody know the ID of the fuel line hose? I can't seem to find it in the manuals and I'm a couple hours from my boat. Thanks for any input.
Mark and Karen Gadson
St Michaels, MD
1995 Catalina 36 Mk II (Hull 1458) - Tall Rig; Wing Keel; M35
​Home Port:  St Michaels, MD
Boat Name: Magnolia
rjwilson's picture
rjwilson
I replaced mine last year and my records show I used 3/8" line between the tank and filter housing.
Bob Wilson
S/V Morning Breeze
2003 Catalina 36, Hull 2122
York River Yacht Club
Williamsburg, VA
Better check with a full visual on your own boat's system as these pumps are rated at 60 GPH and comes with 3/4" ports. My hose from the tank to engine's fuel filter id 3/8ths inches.
jswesterman
Mark - I'm in a similar situation - need to know the fuel line size and over a hour from the boat.  Did you use 3/8" as the fuel line from the tank to the Racor primary filter?
Anyone know the size of the fuel return line?
Jeremy
Jeremy Westerman
"Odette", 2005 Catalina 36 Mk II, #2213
Benicia, CA
I have 5/16 on my M25, both return and supply.
Les
