main sheet rope size?
ludo's picture
ludo
Hello
Since I own the boat I have the feeling my main sheet is too big for the clutch, what is the recommended size? Any advice on the type of rope, the size and the length I should get?
As you can see in the picture, right now I have a 9/16in (14mm) rope in a spinlock XTS CAM-0814 clutch.
Is it the original clutch shipped with the boat? It looks this clutch was replaced during the lifetime of the boat.
Ludovic François
Marina Del Rey, CA
according to page 21 of the manual - it is 80' of 7/16.  I'm sure they delivered the boats with lots of different hardware over the years - mostly Schaefer & Garhauer.
Those lines look sad.
caprice 1050
​I have been using 7/16 line since I have owned my C36, That 80 foot length seems a little short to me. I usually take my old sheets off, measure them, then get five feet longer. Every year I take them off, reverse them to prevent wear in spots and use them again.  If they are long enough I untie them, cut off a few feet and retie,  this is another way to also move the potential wear spots.
William Miller
I called Catalina and I believe they said it was 3/8 and 112 feet Call to check . I used a line called warpspeed. Very strong. One thing you will notice ic how easy the main will haul up
[quote=William Miller]I called Catalina and I believe they said it was 3/8 and 112 feet Call to check . I used a line called warpspeed. Very strong. One thing you will notice ic how easy the main will haul up[/quote]
That sounds like the main halyard -- not the sheet.
William Miller
You are right .Thats what I get for reading too fast
