What is the diameter of the "U" shaped masthead bail for the spinnaker block? I don't want to get up there and find out the block I have is too small to fit the bail.
Bill Deliman
Bill Deliman
Vivacious 2
Atlantic Highlands, N.J.
If you don't get a reply. I would go to West Marine and buy thee blocks of different sizes, then after I put the correct size one on the mast I would return the two that I didn't need.
Or simply call Garhauer and tell them what you need. Might as well get the right part to start.
Bruce Campbell
Evergreen Dreams #1409
I second what Bruce said. Most likely they will steer you to their 40-13 series swivel blocks. I believe the diameter of the material for the masthead bail is 5/16". Hope this helps.
